Setting Up Notification Types
Each notification type defines the controls and behavior for defining communication preferences and sending out notifications of that type.
There are two main categories of notification types: subscription and push. These behave differently. Refer to
Push vs. Subscription Notification Types for more information.
Push notification types are configured as either parent or individual push notification types. A parent push notification type is used to define communication preferences and an individual push notification type is used to send notifications. Refer to
Parent vs. Individual Push Notification Types for more information.
The base product supplies one Notification Type business objects. For more details, refer to the specifications for this business object.
Some notification types require specific configuration. Refer to
Designing Notification Types for more information.
To set up notification types, select > >
The
Notification Type Portal contains the following zones:
Parent topic
