Setting Up Tax Exempt Types
Your rates will probably have provisions for the calculation of taxes of one type or another. Frequently you will have customers who are completely or partially exempt from these taxes. The service agreements for these customers will need to have tax exemption information in order for them to be billed properly. Tax Exempt Type is used to define the precise nature of the applicable exemption. To define the Tax Exempt Types you will use, open > >
Description of Page
Enter a unique Tax Exempt Type and Description for each type of tax exemption.
Parent topic
