Activity Type | Step | Step Type Action |
Connect SP and install lamp | Connect SP to power source | Connect Service Point |
Install lamp | Install Item | |
Attempt to notify owner - optional | Contact Customer | |
Connect SP | Connect SP to power source | Connect Service Point |
Disconnect SP | Disconnect SP from power source | Disconnect Service Point |
Install lamp | Install lamp | Install Item |
Remove lamp and leave connected | Remove lamp | Remove Item |
Install eye | Install eye | Turn On Item |
Remove eye | Remove eye | Turn Off Item |
Remove and disconnect lamp | Verify premise is vacant - optional | Contact Customer |
Remove lamp | Remove Item | |
Disconnect SP from power source | Disconnect Service Point | |
Disconnect warning | Place disconnect warning | Contact Customer |
Reconnect lamp | Install eye - optional | Turn On Item |
Install lamp - optional | Install Item | |
Cut lamp for non payment | Remove eye - optional | Turn Off Item |
Remove lamp - optional | Remove Item |
