Field Activities Initiated To Start Service
Use the customer event Start to define the field activity(s) used to start service at a service point whose SP type references this profile.
Description of Page
Where Used
The start service process uses this information to determine the type of field activities to create to start service at a service point.
Warning:
Warning. Field activities will only be created for starts if you have defined the appropriate field work creation algorithm on the service agreement's SA type. Refer to
SA Type - Algorithms for more information.
Parent topic
