Sample FA Integration Algorithm
The system provides a sample algorithm for FA integration called FWFM-FA-INT. This algorithm creates outbound messages (by creating NDS records) to notify an external system if any field activities are created or if any changes are made to existing FAs so that their corresponding orders are created or updated respectively. Refer to the algorithm type description for more detail about the algorithm's logic.
Alert For Problems With Message. The base product provides an alert algorithm (CCAL-FAERMSG) that may be plugged in to the
installation options. This algorithm displays an alert if there is an error associated with an outbound message for the field activity or if a response has not been received within a specified time limit.
Parent topic
