SP Condition | Customer Event: Start Service | Customer Event: Stop Service | Customer Event: Start/Stop Service |
No Device / SP Disconnected at meter | Install meter and connect line | N/A - no field work is necessary because the meter should have been read when it was removed | N/A |
No Device / SP Disconnected at pole | Install meter and connect line | N/A - no field work is necessary because the meter should have been read when it was removed | N/A |
No Device / SP Connected | Install meter | N/A - no field work is necessary because the meter should have been read when it was removed | N/A |
Device Installed / Device Off / SP Disconnected at meter | Connect line and turn on meter | N/A - no field work is necessary because the meter should have been read when the service was severed | N/A |
Device Installed / Device Off / SP Disconnected at pole | Connect line and turn on meter | N/A - no field work is necessary because the meter should have been read when the service was severed | N/A |
Device Installed / Device Off / SP Connected | Turn on meter | N/A - no field work is necessary because the meter should have been read when the meter was turned off | N/A |
Device Installed / Device On / SP Connected | Read meter | Turn off meter | Read meter |
Device Installed / Device On / SP Disconnected at meter | Connect line and read meter | N/A - no field work is necessary because the meter should have been read when the line was disconnected | N/A |
Device Installed / Device On / SP Disconnected at pole | Connect line and read meter | N/A - no field work is necessary because the meter should have been read when the line was disconnected | N/A |
