Different Collection Criteria For Different Customers And Different Debt
Consider the following:
• You probably have different collection criteria for different jurisdictions (i.e., CIS Divisions). For example, if you have customers in different states / provinces, you may have different regulator-imposed criteria applied to each state's debt. You differentiate your debt in respect of the collection process via the CIS division code on each customer's account.
• You probably have different collection criteria for different customer segments. For example, customers with large bills probably have strict criteria, whereas you're probably more lenient with small customers (or vice versa). You differentiate your customers in respect of the collection process via a collection class code on the customers' accounts. An account's initial collection class is defaulted from its customer class. You may override an account's collection class at will.
• You probably have different collection criteria for different classes of debt. For example, if a single customer has both regulated and unregulated debt, you probably have commission-imposed criteria to be applied to the regulated debt, but you have the freedom to apply stricter criteria to the unregulated debt. You differentiate your debt in respect of the collection process via a debt class code on the customers' service agreements (note: the debt class is actually defined on the service agreement's SA type).
• You will have different criteria for every currency in which you work because the monitoring process always compares a customer's debt against some value and this value must be denominated in the customer's currency. A customer's currency is defined using a currency code on the account.
Given the above, you should understand that different collection criteria will exist for every combination of CIS division, collection class, debt class, and currency code. If you're confused, consider the following matrix (where we assume you have a single currency and division and therefore avoid the third and fourth dimensions):
SA's Debt Class | Account's Collection Class: Commercial Customer | Account's Collection Class: Residential Customer |
Regulated | N/A - there is no regulated, commercial customer debt. | Highest Priority: If > $5 in arrears by more than 50 days, create the accelerated collection process for residential customers. Lower Priority: If > $25 in arrears by more than 25 days, create the courtesy reminder collection process for residential customers. |
Unregulated | Highest Priority: If > $10 in arrears by more than 50 days, create the accelerated collection process for commercial customers. Lower Priority: If > $1000 in arrears by more than 25 days, create the normal collection process for commercial customers. | Highest Priority: If > $10 in arrears by more than 25 days, create the normal collection process for residential customers. |
Charitable Contribution | Highest Priority: If > $10 in arrears by more than 50 days, create the charitable collection process. | Highest Priority: If > $10 in arrears by more than 50 days, create the charitable collection process. |
Also, notice that there can be multiple criteria for each cell in the matrix. What differentiates one collection criteria from another is its priority. The higher priority criteria will be compared first. If the debt meets the criteria, the collection process is initiated and no further comparisons are performed.
Fastpath:
For more information about maintaining this matrix, refer to
Setting Up Collection Class Controls. For more information about how the system handles an element in this matrix that has multiple criteria, see
How Is An Account's Debt Monitored?.
Parent topic
