Defining Meter Location Codes
When you set up a metered service point you must define where the meter's service point is located on the property.
The meter location code is provided to meter readers and field workers to help locate the meter.
To define meter location codes, open >
Description of Page
Enter a unique Meter Location and Description for every meter location.
Parent topic
