Designing Your TOU Codes for TOU Mapping
The next most logical step in designing your time of use mapping controls is to define your time of use codes. To do this, look at the time of use periods to which your usage needs to be mapped. These values will likely correspond to the time of use quantities that your rate bills for. It should be noted that it's possible that will not bill for every time of use period.
For more information about time of use, refer to
UOM versus TOU versus SQI.
Parent topic
