Designing Your TOU Groups for TOU Mapping
To further aid in designing time of use mapping, the TOU Group enables you to group together all the time of use codes that are available to be used in a single map. You must also decide if you want to use a sequence number to define the relative order of a TOU code within a TOU group.
When TOU data is created for a TOU map, only TOU periods defined on a specified TOU group can be specified.
Parent topic
