Device Test Type - Characteristics
Open > > > and navigate to the Characteristics page to define required and optional characteristics for device tests of a given type.
Description of Page
Define Characteristic Types to describe characteristics that might be entered for all tests of this type. Turn on Required if this type of characteristics must be specified on tests of this type, otherwise, the characteristic will be optional. Enter a Characteristic Value to use as the default for a given Characteristic Type when the Default switch is turned on. Use Sequence to control the order in which characteristics are defaulted.
You can only choose characteristic types defined as permissible on a device test type record.
Parent topic
