Meter Reader Remark - Main
To define meter read remark codes, open > > >
Description of Page
Enter a unique Meter Reader Remark and a Description for every meter read remark.
Turn on Eligible for Processing if meter reads marked with a given remark code should cause one or more Action Algorithms to execute. For example, if you need a "reread" field activity to be created when a "high bill" remark is uploaded, you'd create an algorithm called "reread" and associate it with the "high bill" remark code. Then, whenever such a meter read with a "high bill" remark is recorded in the database, the system will execute the algorithm (and generate the field activity). If you haven't done so already, you must set up this algorithm in the system. To do this:
• On this algorithm, reference an Algorithm Type that is associated with a meter read remark special activity.
Parent topic
