Allow Estimates Segmentation
Every SA Type has a switch that controls whether the system estimates consumption if meter reads are missing at billing time. If a given SA Type has different situations when the system should and should not estimate, you will have to split the SA Type.
Override. You can override the value of the SA Type's estimation switch on an individual service agreement. This means that if only a few service agreements don't abide by the SA Type's estimation switch, you can change the switch value of these service agreements.
Fastpath:
For more information about estimation, refer to
Setting Up Consumption Estimation Parameters.
Parent topic
