Merchandise Segmentation - Installment Billing
If your organization allows customers to purchase merchandise using an installment plan, you must create a SA type for this.
No installments. If the customer must pay for the merchandise in one lump amount, you'd create an SA type similar to the
Connection Charge Segmentation example.
CIS Division/ SA Type | Service Type | Distrib. Code | Debt Class | Bill Seg Type | Recurring Charge Control Info |
CA/MERCH-I | Merch | A/R-MRCH | UNRE | RECUR-AS | Amount to bill is Not Allowed Amount is Required Frequency is Monthly Recurring Amount Label is Install Amount |
Notice the following about the new merchandise SA type:
• It has a normal receivable distribution code.
• It uses an interesting bill segment type - RECUR-AS. This bill segment type was set up to create recurring charges that stop when the customer no longer has a payoff balance.
• The recurring charge control information is set up as defined.
Fastpath:
Refer to the Description of Page under
SA Type - Billing for the definition of the recurring charge attributes. Refer to
Start Option Considerations For SA Types That Use Recurring Charges for how you can use start options to automatically populate a service agreement's recurring charge fields with appropriate values when service is started. Refer to
Start Option Considerations For SA Types That Use Initial Adjustments for how you can use start options to automatically populate a service agreement's recurring charge fields with appropriate values when service is started.
Parent topic
