Start Option - Interval Info
Fastpath:
Refer to
Designing Your SA Interval Billing Options for information about setting up start options for interval service agreements.
This tab may not appear. This tab is suppressed if the interval billing Complex Billing module is
turned off.
Open > > > and navigate to the Interval Info page to define the start option's interval profile and TOU map default values.
Description of Page
The collection of interval profile information will be used to link interval profiles to a service agreement that will be created with this start option. The Interval Profile Relationship Type indicates the value that will be linked to each new SA Profile record. For each interval profile relationship type, define either an Interval Profile Type or an Interval Profile ID depending on whether the Profile to be linked to the new service agreement should be SA Specific or Shared. For SA Specific, indicate an interval profile type. This will cause a new interval profile to be created with this interval profile type and the new interval profile will be linked to the new SA at start time. For Shared profiles, indicate the Interval Profile ID. This will cause the specified Profile to be linked to the new SA at start time.
If a Derivation Algorithm is linked to the interval profile type, then the algorithm and its Creation Priority are displayed.
Fastpath:
For more information about interval profile relationship types, see
Designing Interval Profile Relationship Types. For more information about Shared profiles vs. SA Specific profiles, see
Common Profiles vs. SA Owned Profiles .
The collection of TOU map information will be used to link TOU Maps to a service agreement that will be created with this start option. The TOU Relationship Type indicates the value that will be linked to each new SA TOU Map record. For each TOU relationship type, define either a TOU Map Type or a TOU Map ID depending on whether the map to be linked to the new service agreement should be SA Specific or Shared. For SA Specific, indicate a TOU map type. This will cause a new TOU map to be created with this TOU map type and the new TOU map will be linked to the new SA at start time. For Shared map, indicate the TOU map id. This will cause the specified map to be linked to the new SA at start time.
If a TOU map creation algorithm is linked to the TOU Map type, then the Derivation Algorithm and its Creation Priority are displayed.
Fastpath:
For more information about TOU map relationship types, see
Designing Your TOU Map Relationship Types.
Parent topic
