Setting Up Market Provider Configuration Options
This portal is used to maintain Market Provider Configuration Options.
You can access the portal from Admin > Open Market > Market Provider Configuration Option. You are brought to a query portal with options for searching for a specific Market Provider Configuration Option. Once a record is selected, you are brought to the maintenance portal to view and maintain the selected record.
The following zones may appear as part of the portal's Main page:
Market Provider Configuration Option zone shows the details of the Market Provider Configuration Option.
Service Provider Market Options zone shows the service providers with their start dates, end dates (if applicable) and statuses. Maintenance actions are provided. A broadcast icon appears if the Service Provider Market Option has sub-SA(s) and/or entries in the Status History log. Clicking on the broadcast icon displays the following zones:
Service Agreements zone shows the Service Provider Market Option’s sub-SAs.
Status History zone shows the history of changes to the Service Provider Market Option, which can include changes to Start Date, End Date and/or Status.
