Setting Up Service Providers
This portal is used to maintain Service Providers.
You can access the portal from > > . You are brought to a query portal with options for searching for a specific service provider. Once a service provider is selected, you are brought to the maintenance portal to view and maintain the selected record.
The Service Provider zone shows the details of the service provider. Refer to the zone’s embedded help for more information.
Parent topic
