Physical Attributes of Raw Interval Data
Raw interval data is available for use by algorithms in the system to create billable data for the service agreement. This data will not have any 'business' role, as with the billable interval data, described above.
As a result only 'physical' attributes of the raw interval data need to be defined, such as:
• Unit of Measure
• Minutes per Interval
• Service Quantity Identifier
This information is defined on the Interval Register Type.
The
interval register type may also include algorithms related to its data:
• Validation algorithms may be used to check and correct various conditions related to the interval data.
Refer to Validation of Register Data for more information. Parent topic
