SA Used for Miscellaneous Transactions
For some memberships, you may need to define a special service agreement to use for miscellaneous transactions. For example:
If events created for a membership cause an adjustment to be created to affect the general ledger, rather than allowing the system to arbitrarily pick a service agreement to use for this adjustment, the SA to use should be indicated on the membership. Refer to
An Event May Cause Other Actions to Occur for more information.
Parent topic
