SC Membership Type - Algorithm
Open > > > and navigate to the Algorithm page to define any algorithms that are associated with a membership type.
Description of Page
The grid contains Algorithms that control important functions in the system. You must define the following for each algorithm:
• Specify the System Event with which the algorithm is associated (descriptions of all possible events are provided below).
• Specify the Sequence and Algorithm for each system event. You can set the Sequence to 10 unless you have a System Event that has multiple Algorithms. In this case, you need to tell the system the Sequence in which they should execute.
The following table describes each System Event for which you can define algorithms.
System Event | Optional / Required | Description |
Membership Creation | Optional | Use this system event for algorithms that are executed when a membership is created. |
Membership Activation | Optional | Use this system event for algorithms that are executed when a membership becomes active. Note: Creating Memberships In Active Status. A membership may be created in either pending status or in active status, based on your business practice. For memberships created in active status, the system executes the membership creation algorithms and the membership activation algorithms. |
Membership Inactivation | Optional | Use a system event of Membership Inactivation for algorithms that are executed when a membership becomes inactive . |
Parent topic
