Setting Up Service Credit Event Types
Service credit events created for a service credit membership have an event type. Open > > to set up service credit event types.
Description of Page
Enter a unique Service Credit Event Type and Description for each event type.
Indicate the Service Credit Membership Type to which this event type belongs.
The grid contains Algorithms that control important functions in the system. You must define the following for each algorithm:
• Specify the System Event with which the algorithm is associated (descriptions of all possible events are provided below).
• Specify the Sequence and Algorithm for each system event. You can set the Sequence to 10 unless you have a System Event that has multiple Algorithms. In this case, you need to tell the system the Sequence in which they should execute.
The following table describes each System Event for which you can define algorithms.
System Event | Optional / Required | Description |
Event Completion | Optional | |
Event Cancellation | Optional | Use this system event for algorithms that are executed when an event is canceled. |
Parent topic
