You must set up a
bill factor that defines the interest rate. If you have different interest rates for different types of loans, you can create a separate bill factor for each or you can use start options to override the interest rate.
On the bill factor's
bill factor value, make sure to reference the GL distribution code used to book interest revenue for the revenue class specified on the loan's SA type.
