SA Type - Detail
Define the following options:
• Special Role is Loan.
• Specify the Interest Bill Factor set up above. You can use start options to override.
• Use Override Interest to indicate whether the interest rate defined on the interest bill factor may be overridden at the SA level. If you select Allowed, the interest rate may be overridden by a contract value on a start option or the SA.
• Use the short-term receivable account defined above as the Loan A/R Distribution Code. If you do not want the system to differentiate between short-term receivables and long-term receivables, make the loan A/R distribution code the same as the distribution code (above).
Parent topic
