Case Info May Be Formatted By An Algorithm
An algorithm may be plugged in on the
installation record to format the standard case information that appears throughout the system. Refer to CSIN-DFLT for an example of this algorithm.
This algorithm may be further overridden by a "Case information" plug-in on the
Case Type. Refer to C1-CT-INFO for an example of this algorithm.
Parent topic
