Designing Workflow Process Criteria
The matrix's second dimension is dependent on workflow criteria algorithms. Workflow criteria are confusing. Think of them as optional conditions that, if met, will cause a different type of workflow process to be started when a given notification upload type is received.
You must define a Default criterion in case none of the override criteria are met. You MAY have override criteria if different situations result in different types of workflow processes. For example, let's assume some notification upload types have different workflow processes for industrial customers as compared to all other types of customer. This assumption necessitates the introduction of an override workflow process criteria; we'll call it Industrial Customer.
WF Process Criteria Notif. Upload Type | Default | Industrial Customer |
Retrieve a customer's consumption history | | |
Switch a customer to a different service supplier | | |
Switch customer to an interval meter | | |
The workflow process criteria are limited by your imagination (and business requirements). We have provided the workflow process criteria you see above as an example; we don't expect you'll be able to use the exact conditions we supply. Your conditions will be based on any number of factors.
New workflow process criteria may require programming. See
How To Add A New Algorithm for more information.
Parent topic
