Executing Workflow Events On Their Trigger Date
When the background process (referred to as WFET ) executes a workflow event on its trigger date, it calls the activation algorithm associated with the event's event type. Because you can add and change activation algorithms at will, the variety of workflow events is infinite.
Fastpath:
Refer to
Designing Workflow Event Types for more information about activation algorithms.
Parent topic
