Notification Download Type - Main
Every notification download staging record has a notification download type. This code controls the format of the record that is sent to a service provider. Open > to define your notification download types.
Description of Page
Enter a unique Notification Download Type and Description.
Specify the XAI In Service Name that will be called for this NDS type if the download profile formatting method indicates that this download type will be processed by XAI.
Enter a value for the
Download Type Condition Flag when a system condition should trigger the creation of a notification record. Refer to
System Conditions May Trigger Notification and Workflow for more information.
The values for this field are customizable using the Lookup table. This field name is NT_DWN_TY_COND_FLG.
Indicate the relative Priority for processing NDS records of this type with respect to other types. This value defaults to Priority 90 - Lowest.
The values for this field are customizable using the Lookup table. This field name is NT_DWN_TY_PRIO_FLG.
Parent topic
