XAI Route Type
Use this page to define information required by the XAI tool to send outgoing messages. Navigate to this page using > > >
Description of Page
Enter the XAI Route Type, which defines the information required for outgoing messages, which use the XAI tool. Enter a Description for this route type.
The XSL Request is the schema used to transform information from the format produced by the system to a format understood by the sender, who receives a message of this type.
The XSL Response is the schema used to transform information from the format sent to us by the sender, who responds to this message into a format understood by the system.
Use the XAI Sender to indicate where messages of this type should be sent.
Fastpath:
Refer to
Message Sender for more information.
Check the Receive Acknowledge box if the system expects to receive a synchronous response to outgoing messages of this type.
Check the Post Response box if a synchronous response to an outgoing message requires something to occur in the system. If the box is checked, a response to a message of this type causes an XAI upload staging record to be created. That record is processed along with other uploaded messages, to invoke an appropriate service.
Where Used
All outgoing messages are sent through the notification download staging record. Information related to the formatting of messages is defined on a notification download profile.
Parent topic
