Parameter | Parameter Code | Description |
CC&B user | P_USER_ID | No default value. Required. Returns an error message if user ID is null, empty or does not exist in database. |
Batch Switch | P_BATCH_SW | For a single bill print, Batch Switch is 'No' and for multiple bill print, Batch Switch is 'Yes'. |
First Bill | P_FROM_BILL_ID | First Bill Id to print for the Bill Range. |
Last Bill | P_TO_BILL_ID | Last Bill Id to print for the Bill Range. |
Batch Code | P_BATCH_CD | Passed in by the system the report is submitted in batch. Only bills with a Bill Routing that references this batch code are selected. |
Batch Number | P_BATCH_NBR | Passed in by the system the report is submitted in batch. Only bills with a Bill Routing that references this batch number are selected. |
Extract Algorithm | P_EXTRACT_ALG | Passed in by the system the report is submitted in batch. Only bills with a Bill Routing whose bill route type references this extract algorithm are selected. |
