Parameter | Parameter Code | Description |
CC&B user | P_USER_ID | No default value. Required. Returns an error message if user ID is null, empty or does not exist in database. |
Batch Switch | P_BATCH_SW | For a single FO print, Batch Switch is 'No' and for multiple FO print, Batch Switch is 'Yes'. |
First FO | P_FROM_FO_ID | First FO ID to print for the FO Range. |
Last FO | P_TO_FO_ID | Last FO ID to print for the FO Range. |
Batch Code | P_BATCH_CD | Batch Code passed in by the system the report is submitted in batch. Only field orders that reference this batch code are selected. |
Batch Number | P_BATCH_NBR | Batch Code passed in by the system the report is submitted in batch. Only field orders that reference this batch number are selected. |
Extract Algorithm | P_EXTRACT_ALG | Passed in by the system the report is submitted in batch. Only field orders whose dispatch groups reference this FO extract algorithm are selected. |
