Specify Reporting Tool Options
The following information should be defined on Reporting Tool Options table:
• Reporting Server is the web server URL where the reporting tool is installed.
• Reporting Folder defines the name of the directory on the Oracle BI Publisher server where reports are located. The system’s reporting tool algorithm constructs the URL to open Oracle BI Publisher Enterprise based on the information provided on Reporting Options. The same folder name should be used as a report folder in Oracle BI Publisher Enterprise where reports are published.
Parent topic
