To Do Entries - CI_TDENTR
Parameters
Parameter | Parameter Code | Description |
ToDo Entry Status | P_ENTRY_STATUS_FLG | Defines if the To Do entries on the report should be limited to those with a given status value. If this parameter is left blank, the report will show all open and being worked To Do entries. |
ToDo Type | P_TD_TYPE_CD | Defines if the To Do entries on the report should be limited to those of a given ToDo type. If this parameter is left blank, the report will show all ToDo type that have at least one open or being worked entry. |
Report Description
The report shows open and being worked To Do entries.
You can limit the report to entries in a given status by specifying the desired To Do Status (open or being worked). If you don't specify a status, all open and being worked To Do entries will appear on this report.
You can also limit the report to entries of a given To Do Type by specifying the desired To Do Type. If you don't specify a To Do Type, all To Do Types with at least one entry in the open / being worked state will appear on this report.
Graphs. The information on this report is shown in both textual and graphical formats.
Parent topic
