Unbilled Revenues - CI_​UBLREV
Parameters
Parameter
Parameter Code
Description
Accounting Period
P_​ACCT_​PERIOD
Defines the accounting period used for the report. A valid fiscal year and accounting period for a valid accounting calendar must be provided.
Account Type Characteristic
P_​CHAR_​TYPE
Defines a Characteristic Type for a characteristic linked to the Distribution Code to define an Account Type.
Account Type
P_​REV_​ACCTY_​CHAR
Account Type Char Value for Revenue related GL Accounts. The char type defined for this parameter should match the Char Type code defined as parameter #2. The parameter value indicated for this parameter should be one that represents revenue accounts.
Report Description
This report provides a simplified calculation of estimated unbilled revenue for a given month.
It processes frozen financial transactions associated with bill segments and canceled bill segments whose bill segment end date is within the Accounting Period (parameter 1). It determines the billed revenue for the FT and then uses this information to calculate the unbilled revenue.
To determine "revenue", the report summarizes amounts posted to any distribution code with a characteristic entry that matches the input Account Type Characteristic type and Account Type characteristic value (parameters 2 and 3).
The estimate for the unbilled portion is calculated as (Bill Amount / Number of Days in the Bill Period) * Number of Unbilled Days for the Accounting Period.
For example, consider a bill segment on a monthly-billed cycle for the period of 3/10/03 - 4/9/03, and for $150 (revenue part of the bill). Assume we are in the April/03 accounting period, which covers 4/1/03 through 4/30/03. This means 21 days are unbilled for April. The unbilled revenue is calculated as 150/31*21 = $101.61.
The following are some points to note about this report.
If the report runs for an historical date, it still estimates the unbilled revenue portion based on the above formula even if actual data exists. In other words, it will not try to find actual bills for subsequent months. As a result, this report always shows what would have been the estimated unbilled revenue for a particular month if that month is the most recent one.
Services can be billed monthly bi-monthly, quarterly or in any desired frequency. This report only performs the revenue recognition estimation using actual bills that were created in the report's accounting period. As a result, it does not estimate unbilled revenue for accounts that were not billed in any portion of the input accounting period.
Revenue recognition practices are unique and may vary from customer to customer. In a given month we can produce current bills (e.g. for electric service) or future bills (e.g. cable services). In addition in some cases we can have bills that started before the accounting period and ending after it (for example in a cancel-rebill situation). This report will only estimate unbilled revenues for bills with the accounting period equals to the report's accounting period.
Performance Consideration. If your implementation chooses to use this report, you may consider adding an index to the CI_​BSEG table on START_​DT, END_​DT to aid in performance. When making this decision, carefully weigh the benefit of improving report performance against the possible degradation to the performance of day-to-day processing as a result of defining a new index. In addition, many companies opt to create a reporting database that is a shadow of production to ensure that indexes defined to benefit reports may be created without any affect on the production environment.
