Bill-Based Write-off
If you write-off unpaid bills, you must set up the following:
Set up the adjustment type that will be used to write-off an unpaid financial transaction. This adjustment type must be configured as follows:
Adjustment Amount Type must be Calculated Amount
Its distribution code is irrelevant as a separate calculation line will be created for each distribution code on the FT's that is written off and these lines will reference the appropriate distribution code.
It must reference an adjustment type char type / value that identifies it as one used to write-off a bill's FTs
The following algorithms must be defined on the adjustment type:
The Generate Adjustment system event must reference an algorithm that has the responsibility of determining how to write-off a FT. This algorithm should be determining the FT's GL details and creating a separate adjustment calculation line for each GL detail. The base package is supplied with a sample algorithm that does this (C1-ADJG-WO).
The Adjustment Financial Transaction system event should reference an algorithm that impacts current, payoff and the GL by the amount being written off.
The distribution codes referenced on the financial transactions must be set up with a characteristic that holds the distribution code used to write-off the original amounts. For example,
Distribution codes used to record tax liabilities will typically reference the same distribution code for write-off (most organizations reverse tax liabilities at write-off time)
Distribution codes used to record revenue will typically reference a write-off distribution code used to record a write-off expense.
Distribution codes used to record receivables will typically not reference a write-off distribution code because receivables are implicitly written off when revenue and tax liabilities are written off.
Set up an adjustment cancellation code used when a users reverses a written-off bill (reversal involves canceling the write off adjustments).
Set up a Write Off Bill algorithm and plug it in on your Collection Class Overdue Rules. This algorithm will reference the adjustment type described in the previous point.
