Installment, Payoff and Current Amounts
Warning:
If you do not understand the difference between payoff balance and current balance, refer to
Current Amount versus Payoff Amount.
When you set up a payment arrangement service agreement (PA SA), you transfer delinquent debt to the PA SA using transfer adjustments. After moneys are transferred, the system sets the PA SA's current balance to zero. At this point, there will be no overdue bills. If the customer neglects to pay bills containing charges associated with the payment arrangement, an overdue process will ensue.
PA SAs start their life with a non-zero payoff balance (i.e., they have debt when first started). This debt is transferred from the bills whose outstanding debt necessitated the creation of the PA SA.
The installment amount that the customer is billed is determined by the number of installments used to payoff the debt. For example, if the customer owes $500 and they want to pay this off in 10 installments, you'd set up the installment amount to be $50. The installment amount is saved on the PA SA's recurring charge amount. If the customer again falls into arrears on their bills, you can transfer additional bills to the PA SA. You can also change the installment amount as needed.
A PA SA's payoff balance typically differs from its current balance. The payoff balance is the amount of debt remaining to be paid off under the terms of the payment arrangement. The current balance is the installment amount that has been billed but not paid. For example, a customer who is paying off $500 with 10 installments of $50 would have an initial payoff balance of $500 and a current balance of $0. After the first bill, the PA SA would still have a payoff balance of $500, but its current balance would be $50. When the customer pays, the PA SA's payoff balance would fall to $450 and its current balance would return to $0.
The following table contains a financial example of a customer who sets up a payment arrangement to payoff $1,000 of debt in $10 installments.
Event | Normal SA's GL Accounting | PA SA's GL Accounting | Normal SA's Current Balance | Normal SA's Payoff Balance | PA SA's Current Balance | PA SA's Payoff Balance |
Prior to creation of payment arrangement | N/A | N/A | 1000 | 1000 | N/A | N/A |
Transfer debt from normal SA(s) to PA SA | Xfer 1000 A/R <1000> | PA A/R 1000 Xfer <1000> | 0 | 0 | 1000 | 1000 |
Set current balance to zero on PA SA | N/A | N/A | 0 | 0 | 0 | 1000 |
Customer is billed ($50 for new debt and $10 of payment arrangement debt) | A/R 50 Revenue <50> | N/A | 50 | 50 | 10 | 1000 |
Customer pays $60 | Cash 50 A/R <50> | Cash 10 PA A/R <10> | 0 | 0 | 0 | 990 |
When the customer pays off the payment arrangement debt, the system automatically closes the PA SA after it final bills (assuming the PA SA's SA type references a bill segment type that has a bill segment creation algorithm of Recurring Charge With Auto Stop ).
Parent topic
