One Bill Per Match Event
As mentioned earlier, a bill is considered paid if its financial transactions (FTs) are linked to a balanced match event. To determine a bill's outstanding amount, FTs from different bills cannot be commingled on the same match event (but it's OK for a bill's FTs to be on multiple match events). If you stick by the rule of "just one bill per match event" you will then be able to determine the outstanding balance of a partially paid bill. However, if you mix more than one bill under a match event, a particular bill's balance may become indeterminate.
The following Open-Item algorithm types have been provided by the base package to help enforce this rule:
• The Distribute by Bill Due Date Payment Distribution algorithm (C1-PYDS-BDU).
• The match by Bill ID Payment Distribution Override algorithm (C1-PDOV-PYBL).
• The FT cancellation FT Freeze algorithm (C1-CFTZ-COFT).
If any of your customized plug-ins and processes create match events, it is important that these too enforce this rule. You may want to refer to the base package algorithms as an example of how to do this.
Parent topic
