Overdue Process Information Is Overridable
"Overdue process info" is the concatenated string of information that summarizes an overdue process throughout the user interface. The base-package logic constructs this string by concatenating the following information:
• The description of its overdue process template
• Its status
• For active processes, the number of days since it was created. For inactive processes, the number of days since it was inactivated.
• For active processes, the unpaid amount of the objects being collected
If you'd prefer a different info string, you can develop a new algorithm and plug-it in on your
overdue process templates. This design allows some / all overdue process templates to have an override info string.
Parent topic
