SA Type - Cut Process Rules
After you've created your cut process templates, you can set up the algorithms that hold your
cut process rules
. These are plugged-in on
SA Type - Algorithm
in the Cut Process Rule system event.
Parent topic
Set Up Tasks
This site works best with JavaScript enabled
