System Event | Optional / Required | Description |
Cancel Logic | Required | This algorithm is executed to cancel a cut event. Refer to How Are Events Canceled for the details. |
Event Activation | Required | This algorithm is executed to activate a cut event on its trigger date. How and When Events Are Activated for the details. |
Event Information | Optional - only used if you want to override a cut event's info string | This algorithm is executed to construct a cut event's override info string. Refer to Cut Event Information Is Overridable for the details. |
Monitor Waiting Events | Optional - only used if events of this type can enter the Waiting state | This algorithm is invoked by the Cut / Cut Event Manager for events in the Waiting state. Refer to Some Events Wait For Something Before Completing for the details. |
