Rate
In order to generate separate calculation lines for the revenue and tax breakdown of the prepaid amount, you need to set up a prepaid rate with components that calculate revenue amount and tax amount given just a total amount.
Create a rate schedule with the following components:
Tax Calculation Rule
Calculation Rule Type = Calculation Algorithm
Value Type = Percentage
Value Source = Bill Factor
Bill Factor = your tax bill factor
Calculation Algorithm = the one created for algorithm type C1-PCTGVNTOT. Refer to Calculation Rule - Calculation Algorithm for information.
Distribution Code = your distribution code for tax liability
Revenue Calculation Rule
Derive SQ = checked
Value Type = Unit Charge
Bill Factor = your rate/kWh bill factor
UOM/TOD/SQI to use for the resulting calculated usage, for example kWh
RC Cross Reference = indicate the sequence for the tax calculation rule (above)
Calculation Algorithm = the one created for algorithm type C1-BACKINREV. Refer to Calculation Rule - Calculation Algorithm for information.
Distribution Code = your distribution code for revenue
