Adding Rebate Definitions
Use the following procedure to add a rebate definition:
Click Add in the title bar of the Rebate Definition zone.
Enter a Description of the rebate definition.
Select the Product for the rebate definition from the dropdown list.
Select the Service Type for the rebate definition from the dropdown list.
Enter the Rebate Per Unit Amount for the rebate definition.
Enter the Rebate Unit of Measure for the rebate definition.
Select the Expense Adjustment Type for the rebate definition from the dropdown list.
Enter the Presumed Energy Savings for the rebate definition.
Select the Presumed Energy Savings Unit of Measure for the rebate definition from the dropdown list.
Enter the Manufacturer and Model for each item eligible to be submitted as a rebate claim line.
To upload manufacturer/model information from a comma-separated-values file, click CSV File to Upload.
Click Browse on the File Upload dialog, and browse to the file to be uploaded.
Click Upload.
Click Save. To return to the Rebate Definition zone without adding the rebate definition, click Cancel.
