Conservation Program Actions
You can perform a number of actions on a conservation program, including:
• Edit: Used to edit a conservation program
• Delete: Used to delete a conservation program
• Activate: Used to activate a pending or inactive conservation program
• Refresh Statistics: Used to refresh the statistics of an active conservation program
• Deactivate: Used to deactivate a pending or active conservation program
• Pend: Used to change the status of an active or inactive conservation program to Pending
The actions available are based on the current status of the conservation program. The table below summarizes the actions available at each status.
Status | Valid Action |
Pending | Edit, Delete, Activate, Deactivate |
Active | Edit, Refresh Statistics, Deactivate, Pend |
Inactive | Activate, Pend |
Parent topic
