Conservation Program Rebate Definition Maintenance Object
A conservation program has rebate definitions that define the rebate amounts and energy savings for different types of products. The superset of such lines is the "rebate matrix". Each row in the matrix defines the rebate and presumed energy savings for a product purchased by the consumer. If your organization wishes to use this maintenance object (MO), you can either use the business object (BO) supplied in the base product or configure your own BO.
This MO provides the following functionality:
The Rebate Definition table can be used to capture information for rebate claim lines such as, appliance type, refund amount, energy savings, and applicable manufacturers and models.
Logs are not provided for the Rebate Definition.
A characteristics collection is not provided.
Fastpath:
For more information, about this MO and to review the business objects defined for this MO, navigate to Admin > Database > Maintenance Object > Search and view the MO C1-RDEF.
