Rebate Claim Line Maintenance Object
A rebate claim has a rebate claim line for each product eligible for a refund. You use the rebate claim line maintenance object (MO) to create a rebate line. If your organization wishes to use this MO, you can either use the business object (BO) supplied in the base product or configure your own BO.
This MO provides the following functionality:
• SA (service): The SA table is the real service SA. There is a separate SA under which the rebate adjustments are stored.
• Logs are not provided for Rebate Claim Line
• The standard characteristics collection is provided.
Fastpath:
For more information, about this MO and to review the business objects defined for this MO, navigate to > > > and view the MO C1-REBLN.
Parent topic
