You can manually start a job stream using the
Job Stream Summary page.
Optionally, you can
set up a schedule defining when the system should start a job stream (i.e., create a workflow process). For example, you can set up a schedule for the "nightly" workflow process template to indicate that a workflow process should be created every night at 5:30 pm, Monday through Friday.
• You can monitor the status of a specific execution of a job stream on the
Job Stream Details page. This page shows the status of the events on a workflow process and a summary of the execution status of each event's batch job.
