Billing Data DataConnect Master Configurations
The master configuration business objects for billing data Configuration for DataConnect define general configuration details for the DataConnect functionality.
Billing Data Configuration for DataConnect
The Billing Data Configuration for DataConnect master configuration is used to configure the UOM, TOU, and SQI of the SA Type's service quantity and charges that will be extracted. Additionally, you can also configure the UOM, TOU and SQI at the rate level.
Billing Extract Master Configuration for DataConnect v1+
The Billing Extract Master Configuration for DataConnect v1+ master configuration is used to define the configuration used to extract billing data. This includes the extraction types, including bill and bill segment sync request business objects, as well as CIS Divisions and SA Types for each, the number of historical periods for initial load, and the calculation line’s category based on the rating engine used (billing extract assumes that only one rating engine is used by the system).
Navigate using Admin, then General, then Master Configuration. In the Master Configuration list, scroll to the appropriate master configuration and click the add icon if there is no record yet or the edit icon to modify an existing record.
For more information about specific fields in the master configuration, refer to the embedded help.
Parent topic
