FK Validation Summary
Navigate to > > to view foreign key validation errors associated with the objects defined in
Master Data.
Description of Page
You can use Table Name to restrict errors to a specific object. If this field is left blank, all errors on all objects will be displayed.
The grid contains a separate row for each type of error. The following information is displayed:
• Table Name is the name of the main table associated with the object.
• Count contains the number of records on this table that have this error.
• Foreign Key Field Names 1 to 6 contain the names of the foreign keys contained on this table that have been found to be in error.
• Foreign Key Values 1 to 6 contain the values within the foreign key fields that are found to be in error.
Parent topic
