SP / Item Suggestions
In order to link an item to a service point, you must
• Link the item to the service point by inserting a record on the CI_​SP_​ITEM_​HIST table.
• In addition, you must also create a CI_​SP_​ITEM_​EVT record. Note the following about this record:
◦ The value of the SP_​ITEM_​EVT_​FLG should be I (for installation).
◦ The value of the ITEM_​ON_​OFF_​FLG should be 1 (on).
