Submitting Insertion Programs
The insertion programs described under
Master Data and
Transaction Data (in the Table Names matrices) are submitted using a batch driver program, CIPVRNIB, and this program is executed in the staging database. You should supply the following parameters to this program:
• Batch code. The batch code associated with the appropriate table's insertion program. Refer to each table listed under
Master Data and
Transaction Data (in the Table Names matrices) for each insertion batch code / program.
• Batch thread number. Thread number contains the relative thread number of the process. For example, if you want to insert accounts into production in 20 parallel threads, each of the 20 execution instances receives its relative thread number (1 through 20). Refer to
Parallel Background Processes for more information.
• Batch thread count. Thread count contains the total number of parallel threads that have been scheduled. For example, if the account insertion process has been set up to run in 20 parallel threads, each of the 20 execution instances receives a thread count of 20. Refer to
• Batch rerun number. Rerun number is not used and should be left blank.
• Batch business date. Business date is the date supplied to the insertion programs and the date under which statistics will be logged.
• Total number of commits. This is the number of commits IN TOTAL that you want to perform. For example, if you have 1,000,000 accounts and you supply a value of 100; then a commit will be executed for approximately every 10,000 accounts.
• Maximum minutes between cursor re-initiation. This should only be populated if you want to override the default value of 15.
• User ID. User ID is only used to log statistics for the execution of the batch job.
• Password. Password is not used.
• Language Code. Language code is used to access language-specific control table values. For example, error messages are presented in this language code.
• Trace program at start (Y/N), trace program exit (Y/N), trace SQL (Y/N) and output trace (Y/N). These switches are only used during QA and benchmarking. If trace program start is set to Y, a message is displayed whenever a program is started. If trace program at exist is set to Y, a message is displayed whenever a program is exited. If trace SQL is set to Y, a message is displayed whenever an SQL statement is executed.
Parent topic
