Validation Error Summary
Navigate to Admin > Conversion > Validation Error Summary to view validation errors associated with the objects defined in Master Data.
Description of Page
You can use Table Name to restrict errors to a specific object. If this field is left blank, all errors on all objects will be displayed.
The grid contains a separate row for each type of error. The following information is displayed:
Table Name is the name of the main table associated with the object.
Message Category and Message Number define the type of error. These fields are the unique identifier of the message that describes the error (the verbiage of this message is displayed in the Message Text column).
Count contains the number of records with this error. Press the Go To button to see the individual records with the error.
